LED marker and tail light strip
RANDAL CHAO
RANDAL CHAO
Orlando Florida
Fixed one issue. Need to add 6ohm resistor to turn signal light wire. Otherwise the truck reports trailer light bulb problem. Fixed.
There is one more issue, the truck somehow thinks there is trailer connected (I only connect the trailer 4 pin light connector, but nothing to the hitch). and hence disables blindspot check. Is there any manual override on this? Really annoying.
Anthony DeVor
Maryland
Connect directly to the taillight wires not the trailer connecter
RANDAL CHAO
RANDAL CHAO
Orlando Florida
Yeah, I could have done that route. Need to take off the tail light assembly to tap to the signal wires. Thanks.
Anthony DeVor
Maryland
Now that wont exactly work if you have separate brake and turn signals in the rear, you will need a 3-2 wire trailer converter then
RANDAL CHAO
RANDAL CHAO
Orlando Florida
It works now. No need to connect to tail light wire. Somehow it was a software glitch that disabled blind spot feature with trailer connected. The service guy unconnected trailer harness, uncheck and check blind spot option settings. Reconnect harness and now it works.
Apollo
VA
Looks good randal.....im liking that spot better than before
jerryhipp
mass
i just tried to splice into the tail light to hook up a trailer hitch light. and it caused the brake light on the truck to stay on. i connected green and yellow wires from the 4 pin to the white with green stripe on truck for the brake light. and the brown from the 4 pin to the green/blue on truck. and white from 4 pin to ground. what did i do wrong? anyone know?
valadorn
