LED Tailight out
swamprat191
california
I have a 2019 Exp Max Limited. Taillight is out. Can I replace individual bulbs or LEDs or do I need a whole new assembly?
HILLY
Greenville, SC
If the amber turn signal is out, you can replace the bulb. If any of the other parking/brake lamps have failed, you need a whole new housing. Unfortunately LED's are not serviceable.
Going_Going_Gone
Phoenix
It's been a while since I had mine apart, but I know you can change the backup lights to LEDs.
S
swamprat191
california
I have the tailight apart right now. My taillight bulb is good and the LED brick works, but the red light around the perimeter does not. I guess this is just another set of LED bulbs??
Left Coast Geek
Mid Left Coast
2019 factory LED tail lights, such as on a Limited, have no servicable components inside. I just looked them up to see what they will cost to replace, at Tasca Parts, they are just under $1000 each. KL1Z-13404-B (Right) or KL1Z-13405-B (Left) for 2019-2021. Fordparts suggested $1500 MSRP.
S
swamprat191
california
Thanks man. That’s the conclusion I came to after tinkering with it a bit. $1000 for a taillight is wild.
brazilusa
Detroit, Michigan
I don't know what they were thinking at Ford for these. "2019 factory LED tail lights, such as on a Limited, have no servicable components inside. I just looked them up to see what they will cost to replace, at Tasca Parts, they are just under $1000 each. KL1Z-13404-B (Right) or KL1Z-13405-B (Left) for 2019-2021. Fordparts suggested $1500 MSRP." They are saying cost for them is $1200 at the local Ford dealer and Ford warranty will not cover mine. They quoted me over $2400 to replace. So, what's all the labor???? Programming??
brazilusa
Detroit, Michigan
Also they don't know the root cause of why my taillight doesn't work. Water condensation sometimes but they can't find any corrosion. Just replace it? ANy aftermarket options?
