Let's See Those Lifted / Big Tire Gen 4s!!
Expy Gator
Florida
If we are talking about lifting and larger tires - is anyone considering a mild fender flare? Personally I think it fits the body well and doesn't make it look so slab sided. Anyone up for a group buy?
NTY18
Alabama
That looks awesome. Love the look. Just bought some Raptor Beadlocks for my wife's 21 FX4 and wondering if I can fit 295/70r17s. Not sure if the FX4 and Wilderness have the same suspension as far as height. I've read that they do and that they don't. I want to install the largest tire possible without a lift. I know it's been discussed a bunch but looking for a definitive answer.
Ediz4riz
Cashiers, NC, USA
2018 Limited Max HD
Lift : Bilstein 5100 F150 struts bottom ring/5100 Expedition rear shocks top ring
Tires :Toyo Open Country AT3 275/65r20 (34.1 inch tall 11 wide)
Rims: Factory 20" with Rough County F150 2" spacers
Does it poke? Yes a little
Does it rub? Yes front tires in front and rear of the tire.
need to pull/adjust fender liners back.
View attachment 41555 View attachment 41557 View attachment 41558 View attachment 41559 View attachment 41561
IMO one of the best looking I’ve seen. Perfect combo!!!
FabLab05
Trying to make what ford won’t!
2023 Timberline running Gen2 Raptor upper and lower control arms, tie rods, Fox. 3.0 non live valve shocks i mounts using the Camburg Raptor conversion buckets. Rear consists of the stock Timberline strut with a machined 2” spacer and longer control arms to center the wheel and tire. 37” BFG K02s on Raptor 37 package wheels. BajaForged roof rack and KC Pro6 lighting. Next is to modify a set of Raptor fender flares to fit!
AKDV
Alaska
Awesome setup. How does it work and is there anything you would do differently?
FabLab05
Thanks! So far it’s working great! Currently only thing I’m going to change is dropping the front lift height by 3/4” and re-gear the diffs. The ride is a bit stiffer which i was looking for, stock ride was a bit squishy for my liking.
ak49
Alaska
Where did you find longer control arms? I wouldn't mind centering my rear wheels after my ReadyLift.
