Has anyone had any luck figuring this issue out or had repairs that solved the problem?
We have experienced this with out 2019 Expedition. Last year the transmission was determined to be the problem and it was pretty much rebuilt and the issue seemed to have gone away for a while, probably 15k miles or so. This summer is started again, and weirdly only driving back to Austin from Houston after an Astros game. Once back home everything seems fine again. This happened probably 3 times. I took it to the dealer to have them look into it and maybe check out the transmission again but they couldn't find any issue, they tried to blame the oil/oil level by saying I hadn't had an oil change in 20k miles and that there was no oil in it. I change my own oil and keep records and I also check the oil regularly and before any out of town trip so I told them that was not the issue. After they checked it out we went on a trip that took us all the way to Florida and back and it ran perfectly until we were getting near Houston and it was pretty bad for the 3 hour drive back to Austin. My issue is there is very poor acceleration until you get past 3k rpms and it starts to build boost. This time I paid attention to the boost gauge and noticed it was trying to max out the gauge under normal driving and once I got to higher rpms the boost looked pretty normal and this is when the acceleration was better. There have never been any check engine lights or alerts in the FordPass app during these occurrences, until a week or two ago and there are 6 messages saying there is a concern with the turbo charger/supercharger control system. Our Expedition has been at a body shop for the past month so we haven't driven it during this time. There is also a message that the voltage is low and the vehicle needs to be driven, so that could be the reason for some of these alerts. This alert does seem to make sense though with the issues I have noticed with the turbo boost seeming to be the issue. Once we get it back from the body shop I'll try to get it back to the service department. The other thing to note is that the Expedition is at the body shop because someone pulled out in front of my wife and she hit them with the passenger side front bumper. So, these alerts could be associated with the repair work going on. It does give me hope though that the service department may be able to use this to diagnose a turbo issue to solve my problems.
In the meantime I was curious if others with this issue have found a resolution.
