I have several of the smaller rechargeable flashlights, but have opted to use the mag-charger as pictured in Hamfisted's post. I thought about mounting it on the side of the console, but if mounted on the driver's side, it MIGHT be in the way and get kicked (or maybe not). If mounted on the passenger's side, it's a LITTLE difficult to access and it MIGHT be in my wife's way (not good). I'm considering mounting it on the top edge of the console just under the radio and climate controls. It's totally out of the way there and is completely accessible too. It doesn't block anything and can be wired in directly to a power source and not take up a power port. I took the upper part of the console out and it looks like adding a piece of one inch by one eighth or quarter inch bar stock 12 inches long(+/-) would be needed to reinforce here since it's nothing but molded plastic and the weight and manipulation of the flashlight and charging cradle coupled with vibration could break this piece. I'll post pictures of the install when I get it done. It looked good just doing a test fit.
