riphip
So glad you got it fixed! I just did the valve body rebuild on a 05 I bought last Monday and went to test drive and it is missing so bad that it wouldn't barely move under it's own power! No check engine light so I need to start trying to find what cylinder is missing. Smells like raw gas out the pipe and the vehicle just bucks and shutters when you try to give it the gas in gear. In neutral it will rev fine with a miss only at idle.I had it towed to my house because of the tranny issue so did not know about the bad misfire until I tried to drive it today.
May want to check out your vacuum lines
