ExplorerTom
Not using premixed coolant. I mix my own 50/50 with distilled water.
I looked into the possibility of electrolysis killing my radiators. I think I ruled out structural failures. And it can’t be just horrible luck.
Electrolysis isn’t a super common failure mode, but it does happen. Read about one particular poor soul who was replacing heater cores at a much faster rate than I’ve been going through radiators.
The good news is that you can test for it. I followed this procedure:
http://ve-labs.net/electrolysis-101/how-to-test
.3V is the bogey. I was at .4V. Bad, but not SUPER bad.
I decided that a good thing to do would be to install the Big 3 Upgrade. This upgrades the battery cables that go to the starter solenoid, the alternator and ground with MUCH larger cables- 0 AWG in most cases, up from 4 AWG.
I could have sourced my own wires and connectors but I decided to buy a kit from HD Circuitry LLC:
https://m.facebook.com/hdcircuitry/
He makes a kit specifically for 10th gen F-150s. He owns one himself.
The kit comes with nice instructions that were easy to follow. I also got to buy a new tool: a hydrualic wire crimping tool. Part of the procress is to repurpose existing cables for something else bu cutting off the ends and reterminating them with ring terminals. I only have hand crimpers and they didn’t even open large enough. And to get a really good crimp, my basic hand crimpers aren’t enough. The hydraulic crimpers are a jack that smashes the wires and connector.
My negative cable from the battery to the frame had seen better days. I was supposed to reuse this cable but instead I replaced it.
All said and done:
It’s a little messy and I need to clean up my aux wiring (especially since I have a fun new crimper!).
Redoing the electrolysis test after the Big 3, it dropped me down to .2V. Better, but not great.
But oddly enough, my radiator isn’t currently leaking. Weird.
All said and done:
