My 2011 Expedition EL Limited
CVguy
CVguy
Cincinnati OH
I’ve been super busy lately, haven’t had much of a chance to update this thread.
September 13th 2024, Can you spot the coolant leak? This was due to the driver’s side coolant crossover gasket failing. An unwelcome surprise on my way to night shift...
With the cooling system already needing attention, I decided to go through and replace everything while I was at it.
267,114 miles, new crossover gasket (only the driver’s side can be replaced without removing the entire intake manifold), Motorcraft thermostat, Motorcraft water pump, and Motorcraft VC-13 “yellow” coolant. The water pump was cheap insurance, in case the original 267K mile pump decided to fail next.
Side note about that coolant - Ford started using orange coolant in 2011, which is what this car had in it. They recently (within the last handful of years) released the yellow coolant which is backwards-compatible with the orange. However, it cannot be mixed with the 2010 and older gold coolant due to the different coolant types chemically reacting with each other. Food for thought for those of you with later 2011+ 3rd gens.
Now that all the excitement was dealt with… Back to the fun stuff!
I’d been wanting a way to keep an eye on the transmission temperature, among other things, so I picked up this super snazzy UltraGauge MX v1.4 (not a sponsor). This allows me to monitor coolant and transmission temp, and battery voltage better than the little dummy gauges in the cluster can.
October 4th 2024, 267,963 miles. Oil change day.
I’ve been using Valvoline Restore and Protect 5W30 (again, not a sponsor... sadly) for the last couple oil changes. It’s supposed to be full to detergents that help clean out sludge and reduce buildup. This is what that oil looks like after 4,000 miles, nice and dark. To the naked eye I’d say it’s working as advertised, it definitely can’t hurt anything and I’m sure this engine doesn’t exactly look spotless on the inside after 267K miles.
November 6th 2024, reached another milestone. Pretty crappy looking picture, but you get the idea. Getting closer to 270K at the time of writing this post.
Here in a little bit, I’ll be replacing the spark plugs and changing the transmission fluid/filter. I’d like to get that knocked out before the snow starts falling soon.
CVguy
CVguy
Cincinnati OH
You could probably guess by my signature that I also have an affinity for Ford Panther cars.
This hobby obsession leads me on a lot of unusual adventures. So, when a 2003 Lincoln Town Car (very similar to the one I own) popped up as a part-out 2.5 hours away east of Columbus, the Expedition made light work of it.
Turns out you can fit 99% of a Town Car interior (literally the whole complete thing, minus the front seats) plus a door in the back of an Expedition EL, with room to see out the rearview mirror. This thing is an absolute workhorse, handles everything I throw at it, and it's a lot of fun using it for hauling stuff like this. I've actually hauled racing go-karts with it in a similar fashion. But I digress...
These parts will be used to finish restoring my fixer-upper 2003 Town Car, which was a mouse hotel back when it sat for over a decade - hence this totally new interior that it needs now.
This will be a fun puzzle to deal with later…
Remember a while back I mentioned this car came from Granville OH? The drive out east took me right through its old home town.
Enjoy an old pic from back in summer. Missing the warm weather and sunshine already.
CVguy
CVguy
Cincinnati OH
I have an Ultragauge as well. Love it. I’ve got it set up to display 8 gauges.
These things are awesome. I much prefer the larger display on the UltraGauge over its rival, Scan Gauge. If I ever get around to it, I'd like to configure a couple extra displays with more gauges too. Definitely a worthwhile thing to have!
1111ExpyEL1111
NW Wisc.
I wish my 2012 Expy EL Limited (and 2016 shortie) had fixed running boards! Have retractable boards on both and they are a PITA to keep functionable here in Wisconsin. Ford really 'effed up in my opinion for not making them greaseable, or at least making it easy to remove, lubricate and reinstall the pins.
EDIT - is there ANYTHING that can be done to be able to brighten the numbers/letters in the dash readout during the day? It's nearly impossible to read during the daytime.
CVguy
CVguy
Cincinnati OH
One solution I could see for that would be to disassemble the hinges and drill and tap some grease fittings in them. That’s something I’m considering trying out with my old running board hinges.
Is your backlight dimmer wheel turned all the way up? Usually I can read my digital display pretty clearly unless there’s insane glare, like driving during sunrise/sunset.
