My last hope on my rough idle
Nick from NE
Nebraska
Hello everyone, as the title states this forum is my last resort before I fork over the cash to a real mechanic.
(video link at the bottom if you care to see it)
First, the issue - the vehicle has a rough idle that gets worse as the weather cools, (the engine temp doesn't affect it) at its worst it shakes the cab and has even stalled out at a light (once in 20,000 miles) in high temps it runs almost normally.
Some info on the vehicle and some of what I’ve done so far.
2000 ford expedition Eddie Bauer 5.4 triton 2 valve awd - 4wd
Codes 171 174 and P0300 the random misfire is only if I let it idle for a while, the lean codes are always there if I’ve driven a bit or idled a while
189,000 miles
fairly small hole in muffler
Engine rebuild at roughly 110,000 miles i’ve seen the receipts and I don’t think the last guy was smart enough to fake them…. Not entirely sure what was done in this rebuild though so take it with about a pound of salt.
Fuel pump at 111,000 according to the grease pencil under the hood
New MAF
Smoke tested for vacuum leaks found some (PCV elbow) , fixed slight improvement
Cleaned original AIC valve with no affect then replaced it with a motor craft one - small improvement in idle.
New battery, not sure if this could have an effect but still
New fuel filter
liquid moly engine oil flush
Injector cleaners of all sorts
Spark plugs
Ignition coils
Replaced faulty upstream passenger side o2 sensor
Regular 3000 miles oil changes with various high end 5w 30 synthetics for the last 20,000 miles Passenger side exhaust manifold gasket
IAT sensor
Air filter
Pulled and cleaned sediment from fuel tank, (learned that a light bulb is an effective redneck fuel float.
AAT sensor
New Napa metal PCV valve
Removed and cleaned entire throttle body.
A few new vacuum lines that were cracked.
Since doing all this I’ve done multiple smoke, water and propane tests looking for vacuum leaks but I’ve found nothing.
I'm attaching a two minute video showing the tac and some live data, as far as I can tell its only really bad in open loop, in closed it appears to be able to compensate, under load the trims improve some but at best it is still adding about 7% on both banks. it only seems to switch to CL if I rev it a few times.
Note on the video - I rev it at the beginning and then I don't touch the gas, brake, ac or anything else for the remainder of the video.
Link to the aforementioned video on YouTube because the quality drops when I post it here.
https://www.youtube.com/watch?v=zG9NPIIJcw0
I really appreciate any help, thank you.
N
Nick from NE
Nebraska
Check the actual fuel pressure. A plugged CAT can throw lean codes, stalling, misfire…
Good call on the CATs I'll take a look tomorrow, fuel pressure came to 35 at idle and 35 at 2000rpm in park, it seems to me it should have jumped when I hit the gas but I've read mixed things so I'm not sure.
DieselMonk
Atlantic Canada
Did you look at the fuel pressure while the engine acts up?
Go around the fuel injectors and see if one is loose. There is a video about it, sucking unmetered air into one cylinder. They should be tight, no little wiggles.
DieselMonk
Atlantic Canada
other than that, I am thinking the intake gasket is leaking. Take a bottle of water while engine running and give it a good squirt of water. If there is a leak the engine starts to shake and miss. The leak may be so tiny that you may not see it with the smoke unless you know where it exactly is. After that, I am out of ideas for now.
eurolux
Raleigh, NC
My 5.4 was running/idling rough but no error codes. Someone suggested a smoke test and I found several vacuum leaks, especially around the PCV, and I fixed all of them. It ran a little better but I wasn't happy. It turns out it was the rubber attachment from the PCV hose assembly on the back of the Idle Air Control Valve. The smoke test didn't show any evidence of a leak back there but I put my hand behind the valve and sure enough there was a small hole. When I replaced it (I have attached a photo with what I ordered from Amazon) the entire rubber piece practically crumbled in my hand. Not sure if this will help in any way but it made a world of difference in how my 5.4 idled/ran. Good Luck!
jr1under
Aiken, SC
This is just speculation but what would cause multiple cylinder misfires if the plugs, coils and injectors are all good? Could it happen from damage to the wiring harness between the cylinder banks and the PCM?
Billme
Hattiesburg,Ms
That's ominous, how would I confirm it?
In my case, something was giving my ICV a command, but also the engine seemed smelly, kinda weird but not as smooth as it should be.. The MAS, fuel trims seemed off.
Like you, I changed every single item, expecting good change..
Another clue was the idle was different most of the time by switching the key off, and restarting..
Anyway, Hamfisted suggested Flagahip1, and the price was right.. Got it changed out, and the difference was incredible..
I don’t think it has ever run this smooth, and so far, everything is holding up great..
Everything is a roll of the dice since a lot of symptoms share the same problem..
02Sexpedition
You could have some wiring damage causing misfire. Especially if it’s in the main harness. You said it was rebuilt. With the amount you claim has been done, it can only boil down to a bad rebuild, wiring, or a computer issue.
JustAnotherExped
Vancouver BC
189,000 miles
New MAF
New fuel filter
Spark plugs
Ignition coils
IAT sensor
Air filter
AAT sensor
I have had a cam follower spit out and therefore had a lean misfire with chuggy idle and poor fuel economy and power. I have also seen a random misfire when a new set of plugs was installed and a difficult to reach one got a small crack during installation.
Gumbyalso
NC
I have a 2000 EB 5.4 4WD since new. It has 378K on it now. Around 200K I chased a vacuum leak for many months doing more than a bit of unnecessary diagnosis by replacement. I finally took it to the dealer. It turned out to be a crack in the intake manifold near the firewall that I would have never found. I paid them to replace the manifold and have never had a vacuum leak since. Your issue sounds very much like mine. They may not have replaced the intake manifold in the rebuild and only replaced the gaskets. The redesigned Ford intake manifold is superior to the original. Other than that intake manifold I have only replaced wear items on that engine (plugs, COPs, PCVs, etc). It has never been rebuilt. I change the oil every 5K with full synthetic and have been using Lucas Engine Oil Stop Leak since around 210K. Engine rattling when cold disappeared with the Lucas and never returned.
1955moose
189,000 miles
New MAF
New fuel filter
Spark plugs
Ignition coils
IAT sensor
Air filter
AAT sensor
Well here goes my 2 cents. I have same SUV, same year. Your lean condition is saying #2 cylinder is lean. That and if you haven't already, fix that hole in muffler. All vehicles have to have a totally sound exhaust. It's not like old days before computers. Also, I'd check #2 fuel injector for power/ground. If good, pop in a known good injector, preferably a new one. Sorry if I missed anything. I'm assuming you did a compression test on at least that cylinder.
JerryT
FL
Exact same problem and fix with my 98 Expy.
67fe390
