Need help asap
ARiley23
Replacing my rear lower trailing arms got the driver side off (cut both bolts) and go to install new arms with new hardware and the bolts that came with are to big to fit in the hole on the frame of my expy. The only logical idea I came up with is to drill out the hole in order for the bolts to fit in.
Any ideas or anything would help out a lot!!
98 Eddie Bauer 5.4 4X4
ARiley23
ARiley23
What did you use to drill it out and how'd u drip out the one by the gas tank?
ARiley23
ARiley23
Okay and how did you drill out the hole by the gas tank and by the brake.
BIG GREEN FORD
loxahatchee Florida
Stock bolts at 14mm new stronger bolts are 16mm. Just got s long drill bit and stuck it through the outside hole and it came out through the 2nd hole next to the fuel tank watch out not to make a hole in the tank. And the one on the axle I did it opposite from inside to out
ARiley23
ARiley23
How do u get them to line up when installing the arms seem too long??!
gourdine
St. Joseph, MO
do these bolt have to be installed from the inside of the frame out with the nut being on the outside? asking because of the gas tank issue on the drivers side lower trailing arms front bolt. thanks
