MikeAndre
I have been searching for a couple days on the internet to find out the specific locations for all the vacuum connections, routing, check valve locations, etc for the 2007 Expedition XLT 4x4. Everything I have found regarding the IWE system refers to the solenoid valve being located on the firewall. I know that my 2007 the solenoid valve and reserve tank are mounted to the fan shroud on the passenger side. I see 2 check valves there near the solenoid but it's hard to see where the rest of the lines go to. Is there only 2 check valves in this system or are there 3? Where is the vacuum intentionally coming from? I believe I'm having the IWE actuators partially engaging while at speed and accelerating. I am thinking their is a vacuum leak and I would like to know the system before I dive into it. Just everything I find is mostly about F150s or different years that is not routed like my 2007.
Any help will greatly be appreciated
Update: After just driving it some more I'm kind of on the fence that this noise is actually the IWE actuators or part of the that vacuum system and think maybe it's in the transmission. Her is why I say that... It sounds exactly like it should be the IWE's and when I put it in 4H the sound goes away. But today while I was driving in 2wd along side a wall so I can hear it better I put the truck in neutral while costing at about 50mph. When put in neutral the sound also goes away even if I give it gas. So the sound goes away when in 4H and when in neutral. My thinking is if it were the IWE system shouldn't it still make the noise while moving in neutral. Could there be something wrong with my Transmission? I did just have the Transmission Oil and filter changed not too long ago. Could the oil level be too low or too high and cause this noise? I'm very close to taking this to a deal, but I hate paying them to wrench on stuff that I can very well wrench on myself.
Hopefully someone here can help me with this.
