Robert Wagner
Now... you'd know that would be too easy!I am surprised no one sells an aftermarket tank in aluminum.
Sent from my SM-T350 using Tapatalk
Noted and thanks!If you can find out what it is really made of Permatex is very good at having something to fix this also contact J-B Weld all of these if you need to seal the cracks I would call the mfg.I have listed and explain what you are dealing with and maybe they can help
Sneaky but I like it!The EVAP monitor won't run when the tank is above 3/4 full, or outside temp is below 40 degrees. It will just show monitor 'not ready'. It also takes 2 failures to trigger the CEL light. Most states allow for 1(or 2) monitors to be not ready, for state inspection. If you keep your tank between full and 3/4 the light will never come on. You just have to clear the code.
This may be the most valuable advice here. If you live in one of the socialist states with all sorts of emission testing it can be impossible to get a tired, rotted out old road-***** to pass the evap test. Took me years to learn what rjdelp is saying here, as it's not widely reported.The EVAP monitor won't run when the tank is above 3/4 full, or outside temp is below 40 degrees. It will just show monitor 'not ready'. It also takes 2 failures to trigger the CEL light. Most states allow for 1(or 2) monitors to be not ready, for state inspection. If you keep your tank between full and 3/4 the light will never come on. You just have to clear the code.
