Hi all. Had an issue with my front passenger brake line blowing out on one of the angled portions after the braided hose part, right where there's a rubber insulating elbow that apparently got water trapped under it. Had enough brake pressure to get home, had it towed to my shop so I could work on it. Long story short I popped the line in question off the ABS pump, flared up a new end on my NiCopp line, and put the original fitting back on and sent it home. However even with no pressure on it and the end of the line just open, I can't get the flare to seal, it keeps leaking from the top of the nut. Tried the Maddox flare tool from HF instead of the cheap performance tool one, tried a new nut, I even gave up and went back to the store and got a factory premade line for double flare, M10x1 thread and it still leaks out the top.
I'm guessing something had to happen to the ABS port, wondering if maybe I overtightened it? I sent the nut until it didn't turn anymore, but didn't force it back that point either. Maybe just a hair past snug was it? Hoping someone can clarify that. But what I also need to know ASAP at this point, are the ABS pumps themselves different between years? The part number I got off Alldata looks like it's specific to my year but I don't know if that's because of the computer half, pump half, or both. The HCU and electronic assembly for my year is over a grand, but if I can buy any old 3rd gen ABS pump off eBay and just swap the computer, I'll save a lot of money.
Also, the fittings for the ABS pump ARE M10x1, right? That's what I read, and that's what I bought at the store and it went in easily by hand
