Bolt snapper
When I bought my new(to me) 2004 Eddie Bauer, the seller said it needed a new driver's side caliper. You could definitely feel a caliper binding, especially at a dead stop when taking off or when shutting the car off (after you released the brake to get out it creaked forward like a parking brake partially engaged).
I put the new caliper on last night and drove it. Seemed to drive fine. It started making a screaching/scraping noise, which I suspected were the little slide clips you put on the bracket for the pads to slide on (they were so loose they were falling off).
So tonight I take it all apart again and bend those little slides so they stay in place, but I cant get the calipers to retract using a vise clamp. I finally have to open the bleeder screw to get it to retract.
I bled it again and it seems to drive fine (once again).
From a diagnostic standpoint, is the only other possible cause an occluded hose acting like a check valve? Any other things I can check before I start throwing more parts at it?
