Hamfisted
Well, the spring should be in place. I think a lot of people making brake job videos on these Expeditions/Navigators/F150s don't even notice the spring during the job and it gets lost and forgotten. But if you are having a hard time getting the caliper pistons to retract using a C-clamp or spreader, you must have other issues in the brake system. If you can re-create the binding pad issue, try cracking the line loose up at the master cylinder and see if you get the same pressure relief that you described above. It may be an issue with the master cylinder itself. When you take the master cylinder reservoir filler cap off is it any easier? Are the rear calipers hard to retract too ? Or the other front caliper? Are the retract springs missing off all the calipers ?
Motorcraft brake parts BRPK 5756 kit ....
