Rutland
(Summary if you dont want to read Tom's Key worked, Dorman didnt.)
I didn't find many posts about this when I was researching, so I thought I'd share my experience.
When I bought my vehicle, it only came with one key. It looked like FORScan could program some lock and unlock functions, but I couldn't find anything conclusive about programming a push-button start key fob. The only DIY options I found online were the Dorman and Tom's Key, both OBD-II programmers.
A few years ago, I purchased a used Dorman programmer on eBay for my Ford Explorer(I couldnt buy FORScan license at the time due to the war and they are based in Russia). It worked great, and I was able to resell it afterward and recover most of the cost. Based on that experience, I spent the extra money and purchased the Dorman 99285 programmer for the Expedition.
I also ordered two new key fobs from eBay. Mine came from a seller named Aurum Auto. When searching for replacement keys, remove the key blade and use the part numbers found inside. I searched using the FCC ID and IC numbers and that seemed to have worked.
When I tried using the Dorman programmer, it appeared to get stuck during the security access portion of the process. The first time, I waited over an hour and a half because I wasn't sure what would happen if I turned off the ignition or unplugged the dongle. I called Dorman, and they verified that I had ordered the correct programmer for my VIN. They took my information and said they would follow up. After not hearing anything for several days, I emailed them. They requested additional information and eventually asked me to have the vehicle scanned for any hidden trouble codes. I sent screenshots showing there were no codes present, but after that I never received another response. Unfortunately, by that point I was past RockAuto's 30-day return window and I could no longer return the Dorman programmer.
I then ordered the Tom's Key programmer. It arrived a few days later. After installing the app and completing the setup, I plugged in the dongle and followed the instructions on my phone. I turned the ignition on, pressed the hazard light button, placed the new key in the cup holder, and less than a minute later the key was successfully programmed.
After confirming the new key could start the vehicle and that the remote start, lock, and unlock functions all worked properly, I followed the Ford owner's manual procedure to program a third key.
One thing to keep in mind is that the vehicle can only have four programmed keys at a time. Luckily, mine only had two programmed keys when I started. I believe FORScan can be used to remove existing keys. Otherwise, you may need to visit a dealership.
Hopefully this helps someone else trying to decide which programmer to use if they lost a key or it came with only one key fob.
