Ben Ford
A little update since I have last posted...
I had a leak in the A/C that I found rather quickly. The condenser was leaking at the tube/tank joint on passenger side as noted by the amount of gunk buildup. I replaced it and the A/C was working amazing!! For two days[emoji19][emoji19]...
The A/C just stopped working. No cold air. Good air flow. Nothing.... I did have a code pop for low pressure. Thought it was the pressure switch and replaced it. Then I tested the compressor by applying power directly to it and the clutch didn’t engage. So, of course I replaced it and the A/C works beautifully now!!!
I don’t drive it much as it’s the wife’s vehicle but she was complaining about the ride quality. So I took it to and from work while diagnosing the A/C issues. Well, with the windows down I could hear a hellacious squeaking and could feel the front end floating whenever I went over some bumps. I knew right away that the struts needed to be replaced. Then I checked for looseness in the front end and wow!!! Everything was toast!!!! I have since replaced Borge front struts, upper and lower control arms, and the outer tie rod ends!!![emoji15][emoji15][emoji15] my wife loves driving it now because she says it drives like a new vehicle. And it better cause of how much money and blood and sweat I put into that front end!![emoji35][emoji35]
Now that the clock has just reached 200k I bought everything I need to replace the timing chain, guides, tensioner, and cam phasers. Not to mention the recommended upgraded oil pump... $1200 for everything!!!! I am now way past the value of the expo. I am now vested in keeping the damn thing....
More to follow on those repairs when I get to it...
