New update to APIM
rugedraw
Miami, FL
Has anyone else yet to receive the new update?
I have auto updates turned on and have yet to receive the new update. It's been long enough that I'm wondering if I should be concerned?
Nah, the OTA process is unreliable and unpredictable. Updates are sent out in batches to groups of VINs at a time. I've seen vehicles go 8 months + without getting any updates sent before the floodgates open and they'll get 3-5 of them within a few weeks.
Mr Big
Tampa Bay, Florida USA
We used to be able to go to the Ford website, download them and install with a thumb drive. I don't see that option anymore.
rugedraw
Miami, FL
With Sync 3, they allowed you to update the APIM that way, but all other modules could only be updated with IDS or FDRS depending on the vehicle. That all changed with Sync 4. The Sync 4 architecture requires the Sync related modules to be updated in a very specific sequence. The APIM cannot be updated unless the GWM or TCU (sometimes the IPC on first gen Sync 4 vehicles where the IPC is seperate from the APIM) is updated first. Allowing an owner to update APIM on their own out of that sequence would create back-end data mismatch problems. With the OTA process, they can control the order in which updates are sent.
Screenshot below is the OTA dashboard of a 2022 Mach E that was very behind on updates until about 4 months ago where updates started rolling in. Notice the sequence ID column. That is the order in which those modules have to be updated. With Sync 3, you could just update the APIM from the oldest to the newest in one shot. On Sync 4 and above, you cannot go from old APIM firmware to the latest without doing a bunch of updates in between.
Even with FDRS, you have to update these modules in order. FDRS will only show one pending update at a time for these modules. Once you apply the update, it will release the next one in the sequence. It is purposely done that way to prevent human error from messing things up.
Mr Big
I just got off the phone with Ford's Digital Experience tech support department. The rep explained everything to me.
I decided to call them because, being in the technology business and beta testing products software and firmware for decades, I pretty much figured out why the rollout is taking time.
They roll out the updates in groups. This is done so the first vehicles that get the updates can report back if any errors occur. This way they can suspend the update rollout if needed. They are basically beta testers. It makes sense as I've read some members mention various issues with the most recent update. Then they roll out the second, third, fourth, and so on. They also update the earlier vehicles along the way to correct any issues that may be reported. The entire process is random. So, we just have to patiently wait until they get to our batch of VINs. She said the vehicle does not have to be on a WIFI to get the updates, just parked, preferably in an open space.
She also told me based on my VIN I would be getting an update in the next couple of weeks. But I'm not holding my breath.
Mr Big
We are not on SYNC4, rather the new "Ford Digital Experience", which is a whole new ballgame. It pretty much cripples anyone wanting to mod some features. They say it's a step forward, but it's really 2 steps backward and requires a subscription to use some of its features.
rugedraw
Miami, FL
Yea, but the digital experience works the same way in terms of the way the module network is updated. The module architecture is actually very similar with the expection of the APIM. I have been itching to play with it, but I no longer work for Ford. I work for a Jaguar/Land Rover dealer now. I am just waiting for someone to trade something in that has the digital experience so I can plug into it and mess around.
Mr Big
That
would be a good thing, because I miss FORScan. I've tried it a few times and have not had any real luck with it. At least we were able to do some cool mods to Sync3 4 before. I even used Fmods to get maps to work on a couple of 21 Explorers that did not come with the feature.
3rd Expyowner123
Just for entertainment sake, just returned from country of Georgia and Armenia. In both countries rode in minivans one streaming YouTube music videos the other wasn’t sure if source on the main center screen with music videos!
Mr Big
Depending on the year, make and model, maybe from 2024 on down, there are hacks that allow streaming while driving. There are also several streaming boxes for our vehicles, compatible with Android Auto and CarPlay, that allow streaming of Netflix, YouTube, many streaming apps, private videos, etc.
DAJinCT
CT
Got an update two nights ago on the Expedition. There is now a linear tach under the speedometer on the instrument panel, and a few more options to select in the gauge area....including a clock if you so choose. BUT......now my coolant gauge is gone. And the RH steering wheel touch pad controls will not function for reverse, skip fwd, or play
I also received the upgrade sometime in the past week. Vehicle was in the shop (whole nuther issue) and I noticed the change when I picked it up. You will now find the coolant temp gauge in settings (not sure which menu but scroll down as it at the bottom) and turning it will be placed to the left of the gear indicator (which is silly that it is not with the other guages if you choose that widget). I have not noticed an issue with the RH stearing wheel touch pad but certainly will be checking that out.
Citka
Bozeman
Got the APIM update. RH steering wheel touch pad controls still function normally for reverse, skip fwd, and play. I did notice that the front seat belt audible warning was re-enabled and the procedure for disabling it does not work anymore. Anybody know of a revised procedure for that?
I am also searching for a solution for the seal belt warning issue. Like you, it came back after the big update and I've had no luck with disabling it again. Almost ready to remove the seat and manually short the sensor wires so it thinks the seat belt is plugged in.
slow3v
Still don't think I've gotten this. Got an update for something unrelated, though.
SENC
SE NC
I have a suspicion, given some of the issues reported here, that the rollout of this OTA update may have been suspended to address those. If that is the case, I certainly applaud the process of rolling out such updates slowly to allow for addressing any issues that arise in the field.
Mr Big
I agree, because Ford told me I'd receive mine in a week and that was a month ago. Also, there are no provisions to download a file and self-load it, as some in the past.
rugedraw
Miami, FL
They don't have a way of knowing when an OTA will be sent. PTS specifically says timing is unpredictable even if an OTA shows as "qualified". You'll get more misinformation from the 800 number for Ford than you will anything useful. They are pure comedy relief.
slow3v
Oct 7 Release Notes
IPMA 26.11.0
We've updated your vehicles image processing module to ensure more consistent and reliable performance.
csnide29
Nova Scotia
The last update I received was EGC-26.2.11.5 on July 20/26.
I know I'm missing a few, nothing earth shattering, but it would be nice to see some progress made on my VIN grouping.
Al_Harley
