No Crank No Start ACC delay relay clicking
97ExpyBigRed
Hi all!
I have a 97 Expedition 5.4 L that will not crank or start, starter is clicking but cannot be jumped, battery is fine and cable connections were cleaned. When turned to accessory or when turning the key before starting, the ACC relay in the fuse box under the left side of the dash is clicking intermittently. Please help!
kkag
Houston, Texas
Did you end up figuring this out? I had a similar issue not long ago, the battery showed it was fine but when I swapped a newish battery from a neighbor just to test it, it fired right up.
geovanni
