No Crank No Start B1352 2008 Navigator
Brantley Navi
I searched for an answer before posting this but did not find my exact situation.
08 Lincoln Navigator L 4x4 5.4 L V8 220k miles
Drive to the store parked it and came out to start back up no crank no start. Battery good, no starter click, all associated fuses and relays are good and when i turn key to start it clicks in the panel on the passenger kick side.
When I put key to run position power straight to starter it starts and runs. I can also jump relay 54, the starter relay, with the key in the run position and it will crank and run no problem.
only code is B1352.
Would y'all change the ignition lock or ignition switch or both?
Or any other insight??
