Donn Rogers
Does anyone have the Horn wiring diagram for a 2011 Expy? I have no horn. No power to the horn assembly.
The horn assembly tests fine by jumping, sounds both high and low.
The #23 fuse on the passenger compartment fuse panel is fine.
Pulled the honk pad/steering wheel air bag. The honk pad is working fine using a multi meter to check continuity.
I am most interested in checking between the fuse panel and the clock spring connector/harness to determine if there is a short between the two or if it is in the clock spring.
Thanks in advance
Thanks in advance
