Nope, you are using Old-School knowledge to make this determination. The Expedition since 2018+ has had an ELSD. The clutches are electronically controlled, so no slipping clutches, because they aren't engaged. They are only engaged when wheel slip occurs, and steering angle is factored in to that decision. These are an open diff, until the ELSD decides to get involved. What you said would be 100% accurate with a mechanical LSD.
The ELSD in the Expedition is the best of both worlds, not engaged when not needed, and there when you do.
Also, there are several Pre 4th gen owners in this discussion...If your Expedition is equipped with an LSD, it is mechanical, and not the same. I have learned you have to REALLY pay attention to realize when the ELSD is getting involved in these 4th gens. It works REALLY well! If you don't think it is working turn off TC, and floor it in Wet conditions, and you will notice a difference.
Also, the ELSD was compared to the brake based TC. No where near the same. Yes, brake based traction control has gotten WAY better over the years, but still not a replacement for a good LSD, manual or Electronic. Brake based TC, stops one wheel from spinning to "Push" power to the one that has traction. Quickly modulated using modern ABS tech it works pretty good, but a LSD moves the power without slowing one wheel.
