My 2016 Navigator (140k kms) was throwing a P0131 code (bank 1 sensor 1 lean). Live data showed that on occasion, the lambda would be stuck (or vary +/- 0.001). Didn't think about it to much but probably more likely to happen when hot. Wiring looked good so I figured I would replace the O2 sensor. But then I read good arguments on replacing them as a pair (either as a bank or both u/s), and I also questioned the longevity of the others so I figured I would tackle all 4.
I live in Ottawa Canada so there's 4 different types of salt that the vehicle drives through each winter. Wasn't sure how the job would go.
Drove the truck up on ramps and was able to access all 4 from underneath. Also picked up an O2 sensor removal kit from my local Part Source loan-a-tool program. I soaked each joint in PB Blaster for I guess a total of 2 days by the time I got around to work on it.
I used the shallow-depth split socket and either a 3/8" breaker bar or long-handle flex-head ratchet and would tap each handle with a 5lb sledge to shock-break the rust bond. Surprisingly that broke them all free. They all came out by hand once broken free (and maybe a few turns with a 22mm wrench; long and stubby 22mm wrenches both came in handy). No heat required. Bank 2 sensor 1 was starting to slip but I tried the hoseclamp technique on the socket and that seemed to help it grip enough to break free. Bank 1 sensor 2 was a pain with the heat shield obstructing it, but the shield could be pushed out of the way to get it out (and pulled back in place to access the electrical connector).Torqued them all to ~34ft-lb (variation because of contorted angles to run a ratchet extension/universal joint/O2 socket to a torque wrench. Probably good and snug by open-end wrench would have sufficed.
I used a screwdriver to either push down a tab or pry apart (while pushing down a tab by hand) the electrical connections. Only the bank 2 sensor 1 connection is in the engine bay (under the intake cover and under that little foam protector piece). For that sensor, I lowered it from the engine bay area rather than try to fish up the wires. The rest are all accessed from underneath.
All parts were OEM Motorcraft:
- DY1185 u/s right
- DY1184 u/s left
- DY1289 - d/s x2.
Probably could have replaced just the one but removal of the others would not be any easier in the future.
All runs good now. Was pleasantly surprised how well it went. It took ~3hrs but I do work slow.
Hope this helps anyone else tackling the job.
- DY1185 u/s right
- DY1184 u/s left
- DY1289 - d/s x2.
