Thanks Jeff. The problem I'm having with the turbo engine on low-speed off-road/crawling is not so much about a lack of torque on the low end as it is about imprecise throttle control. You're right - if the turbo is constantly spooled up in higher speed maneuvers, this isn't as much of a problem.
But when in 4Lo, trying to balance between a) idling slowly up a hill and over rocks and ruts of varying size, to b) feathering the throttle just enough to bump over a rock or rut, the torque can sometimes sneak up as the turbo spools up just off-idle, then I have to use the brakes excessively (NOT smooth) or use both feet. The same issue applies when trying to gently and precisely back a trailer into a parking spot.
I'm a big fan of torquey NA engines (e.g. Nissan's V6s - VQ30DE, VQ35DE - I've actually never owned a V8). At any given RPM, any specific throttle position will return a precise and predictable amount of torque to the wheels. With turbo engines, on the other hand, at a given RPM and throttle position, torque varies and can "sneak up" as the turbo spools up. I can't quite get over my dislike for that lack of predictability. I had an early edition 2007 BMW 335i (3.0 turbo) after owning a '99 Maxima that I raced extensively, and completely regretted switching to a turbo engine in part due to my disdain for the lag in BMW's early 3.0 turbo engines. I drove a 2014 530d the other day and was impressed with how they mitigated lag in that turbo diesel engine. I wish Ford's Coyote 5.0 V8 was offered in the Expedition.
Turbos seem over-rated for every-day driving, but I suppose it's what the consumer market has been demanding as of late.
Good idea with the comforter. I'll have to remember that one if we ever find ourselves stuck in deep snow.
Excellent post and tanks for showing some of us, what our trucks might do if required.
I found your observations re: Turbo/V8 very interesting and to a degree, predictable. I say that because you were doing "work" which required a heavy flywheel and low end torque....neither of which are stalwarts of the turbo design although they did make several concessions to help mitigate the lack of low end power.
I would think had you been doing mountain side sweeper turns at speed, the gracefulness of the turbo spinning at high speeds as you shift electronically would have to be appreciated although the V8 could never match it.
I previously got stuck once in my 1st v8 expy....lay a comforter over the 2' of snow and tucked it under my front tires as best as I could, then put it in 4lo and let off the brake and it climbed to freedom! I'm not sure that the turbo would do the same so easily....
Good post,
jeff
