donl
OK, before anyone starts, I have completed a search and reviewed several threads on this topic but most don't apply to an '03 4.6L 2WD Expedition. Most of the threads I have read and many of the YouTube videos I have watched, some of the DIY guys drained the oil and the coolant but most just drained the coolant. I did watch one video, Falcon's Garage, where he did not drain either. The vehicle was an '03 5.4L 2WD Navigator; no different than an '03 4.6L 2WD Expedition. He removed the oil filter, the plastic piece below the oil filter and clamped the lower hose where it runs under the radiator so there was some drainage when the hose came off but not much. He was able to get to all four bolts with a 3/8" ratchet and socket, no extensions, wobblers, etc. When the bolts came out, the adapter was held loosely in place by the two smaller oil cooler hoses connecting to the backside of the adapter. The old gasket basically fell out when the adapter was pulled back. He slid in the new gasket, bolted all back up, reconnected and unclamped the large coolant hose, installed a new oil filter. The job was done in less than an hour. My vehicle has about 185K miles and there is a drip from that gasket, I have cleaned the area up and am sure the gasket needs to be replaced. I plan to follow Falcon's procedure but wanted to get thoughts, comments, etc. on Falcon's procedure and/or from any members that have made this repair on a 4.6L 2WD '03 Expedition. The only issue I can see could be that if the gasket doesn't come out cleanly and sticks to one surface or the other, I am not sure how much room is available between the adapter and the block to properly clean the two mating surfaces.
