Oil Filter, Which one!
Expensedition
Newport, RI
I am on the early side of my second oil and filter change, with about 3000 miles on the oil and filter.
So I bought the oil and went for the filter and could not find the same Fram XG10575 filter. Then I began doing some research and find myself going down a rabbit hole.
Please elaborate on what you have discovered in your search for a good oil filter.....
Grrumpy
Navy Law Enforcement
OEM Motorcraft is only filter I will use on my Fords. Search on line for oil filter comparisons.....different sites will offer different results, but Motorcraft is always one of the top pics.
It comes standard on your $80-$100 grand Expys, high end Mustangs and everything in-between.......why use anything else ????
Their made primarily by Purolator for the Motorcraft aftermarket while the OE that comes on the new Fords are made by either Purolator or Wix.
Expensedition
Expensedition
Newport, RI
Hmmm, Fram is gone!
I just went on a hunt not believing the online stock at the auto part stores or Walmart, and the Fram XG filters are not there anymore ...anywhere and for the most part All Fram filters for this vehicle are gone.
The motorcraft are basic filters with no screen reinforcement behind the filter media. They are factory specification but what would be better?
Grrumpy
Well, you asked for input and I gave mine. But, it's your choice so use whatever your comfortable with.....As long as you change it along with the oil every 3-5 thousand miles you should be OK with whatever you choose.
LEsoftballdad
NY
The parent company for Fram went through bankruptcy last year, and the rights and equipment were purchased by PGI earlier this year. There were some major disruptions in production, but from my understanding, they should be coming back soon.
I have my local shop use the Wix XP 57502XP on my 25 Expedition.
Expensedition
Expensedition
Newport, RI
Grrumpy, Thank you for the input. The reason I put it to the forum is to get the dump of options from all of the members that have done some research. From there I sort through what I think is a good lead and fine tune my research.
LEsoftballdad, Thank you for the input and I have looked at the Wix but just don't know enough about the company. As I look at the tear-downs online I see the Wix and it is a good filter at the price. I am being driven closer to the idea of increased surface area and reduced micron as well as build quality. The PPE product seems to be the hot item and I do like the idea of a magnet in the filter. The cracking pressure of the bypass valve needs to be a true factor in the selection and that is set at a slightly higher pressure in the PPE. The Wix, although well made with a magnetic screen behind the pleats, great idea, however the efficiency is like 88%@35 microns and that just will not do for me.
The simple way out is to go with the Motorcraft and put the onus on Ford if there is an issue. However I expect to own this puppy longer than any ford warranty and I have a little time to figure this out. I am surprised that so few of the people here are chiming in with oil filter knowledge.
This engine is tiny and is getting squeezed to put out so much power. The ports are small and the revs are high, the turbos alone will spin down after an engine stops. My point is Oil and a good filter, along with consideration of bypass pressure, drain back valve material and build, micron filtration, efficiency...all that plays into keeping the oil clean and the pressure at parameters before it hits the soft bearings. There is a lot to consider and more consideration should be given to the oil and filter.
Grrumpy
Prior to the Expy I had a 2021 Ford Ranger....2.3 turbo. Over on the Ranger 5G forum this subject and oil type/manufacturer was beat to death. Oil was basically left at any good grade of synthetic changed at 5000 miles was good, but the majority went with the Motorcraft filter.
I was a owner for 4 years, and still on the forum, and the general choice is still the same.
I towed a 7000 lb travel trailer with the Ranger for over 20,000 miles without one problem with the engine. Only reason I traded was the need for more room, thus the Expy, which I tow the same 7000 lb trailer.
I have the ability to buy any products I deem fit always getting the best no matter the cost. If there was a better rated filter I would get it.
As for oil....believe it or not, I use Costco Full synthetic 5w30 and have for many years and have never had an engine problem. Same but 5w20 goes in my wife's Subaru Outback Touring....which uses Subaru brand filters.
You can read a dozen different sites that compare filters and you will likely get a dozen different ratings as to which is best......just buy and use what you feel comfortable with.
If you choose another brand I would suggest Purolator, Wix, or Hastings.....just be aware that Wix and Hastings offer several choices within there lineup.....just get the best one.
Expensedition
Expensedition
Newport, RI
Well... The squeaky wheel gets the oil : )
Thank you LEsoftballdad.
More information=better choice
In a nutshell, a constant 10 micron filter is better than a filter that builds to a 10 micron. The data that illustrate 23 microns is too big (damaging) is perplexing and also feeds the theories of planned obsolescence. As most articles indicate, the stock filter and scheduled, on-time filter and oil changes with manufacturer recommended oil can get you a >200K mile vehicle. It all works out to how much do you want to spend on your oil and filter.
I admit to become obsessed with some things, and being around large expensive rotating machinery that requires oil analysis, the condition of the oil in my little 3.5 just happens to be resident in my daily driving evolutions.
The chain is only as strong as its weakest link... For me that will not be the crankcase oil.
Keep the information flowing please.
mr_dave
MN
With Fram out, the oil filter market is a mess right now. I think the best readily available filter right now would be Wix XP.
And as far as that new Lake Speed video with Donaldson, it was decent information... except there isn't a 10 micron oil filter available!! Or at least I can't find one.
34bwood
NY
I did a very extensive filter study earlier this year. I've been obsessed with oil and oil filters since I got my Tremor. I was a little surprised at the current state of the oil filter industry.
A few years ago I never would have predicted what filter I found to be the best. It's Carquest Premium (the 10,000 mile rated one, not extended life).
It's made by Premium Guard Inc in Vietnam. Some of the reasons for choosing it:
99.5% at 20 microns Top Performer - Synthetic Blend Media
  • ADBV: Silicone
  • Service Life: 10,000 miles
  • Silicone Main Gasket
  • Protective film on open end from factory.
  • Sturdy can construction
  • Filter media: proper glue
  • Coil Spring
  • Price: $7.99 with $100 purchase; $8:50 with $35 purchase (online only)
Expensedition
Expensedition
Newport, RI
LEsoftballdad just dropped another great link. That was a lot to digest but Jamin did a great job of keeping my eye on the ball. What I want to glean from it is not what we already know about filters building to spec (rated micron) over time and all of the other particulars about micron size and surface area but instead the details on Wear Units (WU) and why we should be concerned more about that.
The new vehicles with the auto start/stop function contribute to the other engine killer that is wear units. Cold starts are the prime contributor to wear units but the start/stop feature is a component in that math. The auto start/stop feature is based on certain parameters in the software that include the temperature of the oil, so it should never happen with cold oil. The cold oil start is the most destructive component of all machinery with journal bearings. What also should be considered is the time it takes to form the oil wedge in a journal bearing regardless of oil temperature. Considering wear units, the type of oil that we use and the length of time that a lubricating film remains when the oil pressure drops is a major factor in engine life.
In the back of my mind I am considering a spring or gas loaded accumulator such as what is found on larger engines with turbos and this is actually kind of an easy day to install as long as you can find a port on the gallery that is easy to plumb into. Also in that rats nest of ideas a small electric circulating pump that takes suction from the sump inlet, passes through a polishing filter (with no bypass) and possibly a heater before the filter, all of this know as a "Keep warm skid" on a large system. It is also possible to add a sump heater which is the easiest way out to add some additional life to an engine by reducing cold start wear units. Okay... that was off the range a bit....
Back to reality, I bought a filter cutter and started cutting open filters at the shop. Yesterday I bought a K&N gold (white) filter knowing all of the good and bad but considered the details: The K&N gold is farmed to Champion for construction, the internals are made with quality parts, the filter media is a synthetic blend, the selling point is about flow. With that said I am still not ready to put it on my vehicle. Most of the filters that we use in the shop are WIX (Thanks for your input Mr_dave) and I have to say that they are made very well. I need to buy a Carquest premium and open that up (Thanks for your input 34bwood) details to follow.
The verdict is certainly not out and please keep the information coming... Please trash the K&N!!!
34bwood
NY
Flow is the wrong spec to focus on. I retired as a Mechanical Engineer in 2020 and I've always been fascinated with design and numbers. The numbers on filters are very deceiving when you first look at them. Two filters that are rated for 20 microns, but one is 99% efficient and the other 95% are vastly different. The 95% appears to only be 5% worse than the other, but it's not. It's actually 5 times worse (500%). For every particle that makes it past the 99% filter, 5 make it past the 95%. 80% efficient filters are 20 times worse (2000%).
The Puralator Boss gets a lot of love on the internet for its build quality (very deserved) and its flow rate (not needed). It's rated at 99% at 46 microns. That's pretty bad filtration and it may not even meet Ford's requirement: SAE/USCAR-36 spec of 95% at 30 microns. Not sure exactly how 99% at 46 compares with 95% at 30 microns. Not an apples to apples comparison. People like the flow rating of the Boss. Flow is irrelevant except for racing conditions. Autos use a positive displacement oil pump. That means a fixed amount of oil is pumped with every cycle. The exact same amount of oil flows through a more restrictive filter as it does a less restrictive one at any given RPM. You just get a pressure change and it's only about 1-2%. As the RPMs climb, more oil flows. If you're running near redline a lot and for long periods of time racing, maybe a less restrictive oil filter could benefit you if you're reaching the oil bypass pressure limit. Most cars don't see pressure differences higher than the bypass valve's value except in extreme cold or a clogged filter.
I have yet to see any extended mileage filters with decent filtration specs. I'm not sure the technology is there yet. To meet the 20,000 oil change interval they claim, they need to let a lot of the particles flow through the media and only trap the larger ones. The only good filters I've seen are rated for 10,000 miles and at 10,000 miles they're probably close to full.
Good luck on your quest for the bet oil filter. I've currently searching for the best air filter. Air filters are probably the most important filter on the vehicle. The specs aren't as clear and easy to compare as oil filters. Air filters perform so much better once they have a light coat of dust. Their initial filtration value is very different from their value once they start to get dirt load. You don't want to change them too early or you let a lot of small particles through.
5280tunage
colorado
While I don't have any scientific evidence to back up my .02 here, I have a lot of history with many different types of vehicles, including heavy duty off roading, drag racing, and many other situations. On my Gen4, I have consistently rotated between Mobil1 filters and Royal purple. I have used both for years on various turbo, high RPM, and lower RPM V8's and have never had an engine issue attributed to poor oil quality or flow. My justification is that all filters have their strengths and weaknesses. It's like a multi-stage water filtration system, each stage changes the water in a different way. So with different screen backing, different synthetic materials, different flow rates at different particulate sizes, I figure that if one misses a contaminate, maybe the next one will get it. I also often do the same with the oils, but not as much, I generally stick with Mobil1.
But this is like asking what color is the best color...
LEsoftballdad
NY
I got the Auto Start Stop disabler for my 25 Expedition. It was the best $119 I ever spent.
jkp71
Georgia
How often are you planning to change the oil? If every 3-5k miles I'd wonder how much the filter really matters in the grand scheme of things?
Expensedition
Expensedition
Newport, RI
In my last entry I mentioned Wear Units (WU) and stressed the need to focus on filters that filter particles <20 micron. What I found so far is evidence that practically all oil filters will eventually filter to <20 micron as the filter material becomes populated with filtered particles. What is interesting and counterintuitive is that a new filter or constantly replacing a filter before it is time is actually allowing more particles to pass into the machinery.
I need to give some feedback on flow since 34bwood spent some time defining the case. Without going into detail, I agree with what you wrote and will have the unused K&N filter go to the cutter to see what is inside for reference. 34bwood, you could have discussed Bernoulli’s Principle in more detail, just for the fun of it.
There is much truth in what jkp71 said about the grand scheme of things and that it is sometimes best to keep it simple. In some ways I agree and then I see that "ignorance is bliss" warning light, and have to keep going on my quest, or at least try to find as much as I can to make my own decision.
LEsoftballdad seems to be in the same world as me here. As much as I promote the additional benefit of a hybrid where the engine stops in traffic, and had said to my wife years ago if all the cars in the world shut down instead of idle in traffic there would be a substantial savings of fuel and cut in exhaust gas. The problem is that this works fine in a hybrid especially those that have specific motor/generators built right into the drive train, but even with the specially designed motor starter of today that do not use a classic bendix gear, there will still be wear on the flywheel, and I believe they still have graphite brushes, that will wear out. The point of discussion is the increase in engine cranking cycles, where the oil wedge has to form in the journal bearing each time the engine goes from 0 RPM to start (Not going into how many RPMs required for the wedge to form [>30?]).
Mr Big, as much as we use WIX filters all the time on our hydraulic systems, and I agree on the quality I don't plan on using one just yet. I did cut one open at the shop and noted the build quality.
5280tunage, I have used the Mobil 1 filter on all the other Expeditions that I have owned and traded in and it is looking more like the balanced overall winner for me at this point, especially the M1-212A that is made in South Korea, vs the USA product. I haven't looked at the Royal purple but have heard good reviews.
Thank you everyone for your contribution here so far and please continue to add information to this thread.
34bwood
NY
Until recent events, my favorite filter used to be Mobil 1, Royal Purple, Amsoil or Fram Synthetic Endurance. Watch videos where they cut any of them open and you'll see they're the same filter made by Champion Labs (First Brands, their parent company that went bankrupt recently). It's difficult to assess any of those because you may not know if you have one of their new replacements or a leftover from Champion Labs. Premium Guard Inc, that makes Carquest, Premium Guard, Napa Gold, O'Reilly Microguard, purchased Champion Laboratories intellectual properties. Although those Champion Labs filters that I listed were my favorite, they had a tendency to leak at the bypass valve (using a flashlight test) potentially allowing some unfiltered oil back into the engine. Carquest Premium (and the others listed that are the same listed under Premium Guard) doesn't have that issue and has the same or better build quality or better and can be found at a better price.
Member Recommended
Staff online
Lukin
