ExpyOnly
My expedition has 250k miles. The engine was running rough with a misfire code. I changed the spark plugs and coils and I found oil on two of the plugs and coils. After researching forums, others seem to say it's the valve cover gasket, so, I bought a new one and I'm now waiting for the parts to get here. But, my concern is how could it be the valve cover gasket when there are no spark plugs going through the valve cover. I got a P0302 code. And as you can see, that's the area where the oil was leaking into the plugs around cylinder 2. There was also oil inside the injector plug. Do you think replacing the valve cover gasket, plugs, and boots will fix this?
