pgh_expy
I tore the debris shield off yesterday and was able to examine it more closely. The oil seemed to be coming from the plug as many of you had mentioned, and then would run along the bottom of the pan. There was no oil on the vertical side of the pan, opposite the plug, so I think that likely rules out the pan/block gasket as a failure point.
I cleaned it up as best I could, bought a new plug, and took it in for an oil change yesterday. They didn’t see any cracks on the plug but said they’ve seen this issue from time to time and believe it’s the o-ring.
I asked about the massive amount of oil/sludge on the top of the debris shield, and they said given the engine oil level (low but acceptable), it may have been due to a careless oil change. They’ve seen techs remove only a single bolt of the debris shield (closest to the plug), and bend it to access the plug. Inevitably, oil goes everywhere but is largely contained on the debris shield.
I’ll keep monitoring it daily and let you guys know if I see any more leakage. Thanks for your help.
