MOOSEHEAD
2002 EXPEDITION 70k+ MILES. PROBLEM, OVERDRIVE LIGHT CONSTANLY BLINKS AFTER WARM UP. TRIED ADJUSTING AND CLEANING THE NEAUTRAL SHIFT SENSOR AND THEN THE BUTTON WORKED, STOPPED FLASHING TILL IT WARMED UP AND THE CHECK ENGINE LIGHT IS ALSO ON. I PULLED THE BATTERY AND LIGHT WENT OFF, AND BLINKING LIGHT STOPPED, AGAIN TILL WARMED UP, FAILED NJ INSPECTION SO I MUST FIX IT FAST. IVE READ IT IS THE WIRING. POSSABLY BURNT. CAUSING A SHORT. BUT WHERE DO I LOOK. I CANT FIND. ALSO READ ITS THE SENSOR IN THE REAR? IS IT A SENSOR THAT IS IN OR OUTSIDE THE TRANNY?. HELLLLLLP....SERIOUSLY FRUSTRATED
