shadow460
Topic says it all. I fueled up in the bitter cold yesterday and checked all fluids as usual. It needed a little oil so I added some. This morning I got a CEL with P0171 and P0174. I looked under the hood to check vacuum hoses and saw I'd left the oil cap sitting on the washer tank. After putting it back on, long term fuel trim dropped from 23% plus on both banks to 14%.
Since the oil cap seals against the same valve cover the PCV hoses that normally leak seal up to, I assume leaving the cap off is a good way to cause a vacuum "leak".
The CEL is still on. Should I use the scan tool to kill it or will it eventually turn off by itself if the problem is fixed?
