Pins on fuel tank pressure sensor
szarolettaj
Green Bay
I have an 03 Eddie Bauer 5.4l. I had to drop the fuel tank and the wires for the tank pressure sensor pulled out of the harness connector. I know what the wires are, but do not the order that they go into the connector. I don't want to guess and mess something up, and have to drop the tank again to fix it. Does anyone know what each of the pins on the sensor are. One is 5v power, one is ground, and one is the signal. Thanks in advance.1000001144.jpg1000001145.jpg
whtbronco
Winchester, VA
Here's the pinout for a 2004, the connector is the same from 1997-2014 so I suspect the pinout on your 2003 matches mine.
