Hoping for some help from the experts here. Upon cold start, the Oil Temp Gauge does it's on routine but then immediately points to top center of the oil temp circle. Obviously the oil is "cold" and not at full operating temp as the gauge displays.
IF when cold I only turn on full accessory power by pressing start button without the brake applied the Oil Temp gauge does the on routine, then points to top center for a moment and then falls to a level just below the 1/4 "notch" on the gauge.
I began to notice this shortly after the dealer did an oil change. I brought it back to the dealer to address the oil gauge under warranty and upgraded to the fancy NKG95605 spark plugs you all love so much. Dealer said the spark plugs were installed but they have not figured out the oil gauge mystery yet so I picked up the car and drove it home.
Attached a two pics... Engine running a few seconds after cold start and a few seconds after Accessory Power turned on with Engine off. Any ideas to help direct the dealer solve the mystery would be much appreciated!
