Billme
Well I’m back at it again.. I’m going to just let Grok guide me.. I’m curious..
Here is the conversation
I went back and ask grok about your situation.. Interesting readProbably unrelated to your P0500 but I'm curious about the 'B' code circuit failures that BlueDriver is showing. I'm trying to resolve B1318-Battery Voltage Low(which I'm almost certain is valid) and grok is 100% sure it's caused by the door ajar circuit failure. However, there are no indications that anything is wrong with that circuit; all the lights turn on and off as expected and none stay on for more than a few seconds after the doors close. As grok recommended, I doused all six door latches with WD-40 but nothing changed.
I'm not questioning grok's analysis so much as wondering about BlueDriver's scan results. It seems doubtful that a 'circuit failure' would allow all the components on that circuit to work as designed. As usual, there's probably something I don't fully understand and I'd like to hear what it is.
Thanks for that! After updating my grok query, it's telling me this:Yours is basically my situation except I see the effects ..
Never cleared the codes because grok had advised letting the GEM do that after the voltage stabilizes. The battery was disconnected for over an hour while I installed better quality terminals but the codes came right back.Did you clear the codes, and unhook the battery to do a hard reset? Let me know if they comeback
Based on my latest episode, I would do the easiest first like changing the door switch.. It’s a plunger type action and surely gets a workout over this many years in the driver side, then if it shows up, go for the Gem..Cleared the codes yesterday, drove around the block, rescanned and got no codes. This morning after running some errands, the B1318-Battery Voltage Low and B1323-Door Ajar Warning Lamp circuit failure had returned. However, maybe, I understand grok's logic a little better now and the following is my takeaway.
Those codes are no longer considered to be specific problems that need to be addressed but just byproducts of a flaky GEM. If the GEM is compromised in any way - low voltage, corrosion, damage, etc. - nothing it says, does or influences can be trusted.
Next step is to pull the C242 and C243 connectors from the GEM, inspect, and spray the pins with contact cleaner. Grok gives that a 60-70% chance of solving the problem. If it doesn't, then the GEM itself has failed and needs to be replaced.
Thanks, that's what I'll do. Based on the AI consultant, I expected to pop off the kick panel and two GEM connectors would be easily accessible. Yeah, nah, that wasn't the case so I just put the panel back on.Based on my latest episode, I would do the easiest first like changing the door switch.. It’s a plunger type action and surely gets a workout over this many years in the driver side, then if it shows up, go for the Gem..
Lol I know the feeling.. At least you can sit in a chair and fool with the switch..pop off the kick panel and two GEM connectors would be easily accessible. Yeah, nah, that wasn't the case so I just put the panel back on.
I installed the new switch, and still got the bad switch circuit code, but I’m thinking it may be the rear wiper motor which has never worked.. Still have the transmission issue.. All I can think to do at this point is to take enough fluid out, and add some Lucas to see if that helps.. In the meantime I’m going to see if this wiper code allows the other codes to comeback too.. If it does, then the Gem is going to be replaced even if Ifixit said it was good, I guess..A slippery problem and mine now seems even more similar to yours as I had a P0500 show up. No more suspicions about scanner data because I get the same results with BlueDriver and FORScan Lite. Something that makes me still suspect the GEM is that a valid P0500 should cause a CEL but it's not lit here.
Mine hasn't worked in forever so a couple of years ago I disconnected it and pulled the fuse - #12 in the high-current box.but I’m thinking it may be the rear wiper motor which has never worked.
I didn’t realize it had its own circuit fuse. I’ll check it out, thanks!Mine hasn't worked in forever so a couple of years ago I disconnected it and pulled the fuse - #12 in the high-current box.
The timing of both of us having the same problem has me thinking they’re sending destroy signals over the cell network lolA slippery problem and mine now seems even more similar to yours as I had a P0500 show up. No more suspicions about scanner data because I get the same results with BlueDriver and FORScan Lite. Something that makes me still suspect the GEM is that a valid P0500 should cause a CEL but it's not lit here.
