PO500 story continues with new twist
jr1under
Aiken, SC
I have Forscan on the way.. Should have done this long ago
Are you getting Forscan for a PC or for a phone? I've got the Lite version on my phone and it provides way more info than any other scanner I've used. More than I know what to do with but it should be very useful for you.
Billme
Billme
Hattiesburg,Ms
I got both coming, lite, and the laptop version.. I’m really looking forward to trying them out.. Another learning curve to follow hehe..
One thing I’ve run into with this evap system it this motor is definitely designed to run with it.. I’m pretty sure the PCM is keeping the purge valve open.. I’ll know for sure with this next test .. With the new line run, I had already installed everything, and realized I had only checked the wire and connector not plugged in the connector, so I got to test it plugged into the connector, with the connector unplugged from the computer..
Forscan should be here this weekend sometime..
Billme
Billme
Hattiesburg,Ms
Well, the test was good, so I guess it was the green signal wire going to the PCM.. It had a dead short .. Evap purge valve is working again..
This I hope was upsetting the computer and causing all kinds of problems, we’ll see..
Reason I’m hopeful is this hard reset, and test drive was much different, totally new machine, and the TC locked in and shifting was much more solid..
I got my fingers crossed..
Update: The purge valve connector was also bad, I put a needle in the backside to work properly until the new one gets here with the Forscan stuff..
BTW autozone wanted 82 bucks for that connector, I got it on Amazon had one left, for 14 bucks..
I got more to say later
Billme
Billme
Hattiesburg,Ms
I got the Forscan lite going, and I got to say, I should have got this thing a long time ago.. This thing is something…. since I done the last hard reset, and just used the Forscan, I’m beginning to think the BlueDriver was not happy hooked up to this old ford..
Now wouldn’t that be something..
Anyway, everything is looking good so far.. Several test seemed to change how it runs, and how the TC locks in now.. You can definitely tell the difference..
Billme
Billme
Hattiesburg,Ms
Ok, just an update, after monitoring graphs, the problem seem to show itself.. While idling after I was jiggling the switch, about 3 seconds after I stopped jiggling, it was like you turned the switch of but turned it back on before the engine went dead.. So I had this switch done2 years ago, but this time, I’m going to take the front seat out and make a bed, so I can lay down comfortably.. Hopefully this might be the culprit, we’ll see.. While I’m there, and going to clean every connector and put dielectric grease on everything lol
Billme
Billme
Hattiesburg,Ms
At our age, that's just as important as
You got that right! Hehe, That’s funny!
Getting the PO 500 just cranking, so I must be getting close….
I haven’t got under the dash yet, not in the mood, but I can continue my backwards path on redoing and checking under the hood, but I just know it’s the ignition switch connector, because I had that put in.. Onward
Billme
Billme
Hattiesburg,Ms
Sure enough it was not on tight at all. I decided to get to that connector, and glad I did.. cleaned and put dielectric grease on it.. Even if that’s not the culprit, it needed to done right.. I can’t imagine why it was not tight..
Had to take the seat out so I could get to it sideways since I can’t turn my neck.. It hurt but was worth it..
Billme
Billme
Hattiesburg,Ms
I soldered my battery connections, and that got rid of a lot of noise, then took the dash covers off and looked around the wiper multi function switch, and found one that was dangling around which explains several codes..
lots of slop in the key switch to ignition switch.. watching the scope, I could generate a hit, just by a small wiggle on the key..I decided to just change the ignition switch after two years just because seems to loose and watching the ociliscope on Fortran is a game breaker.. I’m not going to attempt the ignition switch until I get another po500 code, because I want to see how fixing that wire in the multi function switch effects the Gem.. The Gem voltage is more stable.. That got my attention…
Trying to figure how lower resolution on my pictures so the forum will upload them..IMG_0936.jpegimage.jpgIMG_0927.jpeg
Billme
Billme
Hattiesburg,Ms
More pictures from above post
Billme
Billme
Hattiesburg,Ms
After fixing that connection in the multi function switch, I eventually got the PO500 again, so I have been getting use to Forscan and realized I could stop in the middle of the scan cycling the key off and on to crank and the
The graft is able to pick it up so I cycle the key several times and produced the PO 500 it has something to do with the accessory delay. On the graph, it shows several consecutive starts and stops with cranking. On the last one, I just went to on, and then went back to off and went to crank, and that produced the results. I’ve been getting that accessory relay code which I thought was a ghost, but apparently it’s not proven by the test..
Still on the hunt, forward !
I’m wondering now if that key cylinder which I noticed as a copper Contacts communicates somehow the accessory delay I’m gonna have to ask Grok I guess..
Billme
Billme
Hattiesburg,Ms
Well, that little slider connector was loose, the keeper tab was broken but was still there, so I used windshield sealer to lock everything in place.. Waiting on it to dry.. The channels had too much play, allowing the whole stationary side give a side motion to that slider connector, probably what broke it and allowed movement..
It’s just worn out but I’m going to add some tape to tighten it up a bit..If I can find my shims, I’ll glue some shim stock in there..
Billme
Billme
Hattiesburg,Ms
Made good progress.. No PO 500 so far, not to mention everything looks solid..
Take all the play out of that key cylinder, and fixing the connector seemingly done the trick, we’ll see..
I used regular see through tape.. I had to use two pieces.. Just place them over the two channels shown, then trim out the middle with an hobby knife, or wherever you have..
Easy mod and should work for a while..
Billme
Billme
Hattiesburg,Ms
Well, that fix didn’t last long lol There something internally wrong with the key cylinder, so I’m ordering a new one on Rockauto along with a new grounding harness.. I can get it working if I hold my mouth right when turning the key lol.. On the good starts, I was able to find a ground problem, that has probably been a cause of a lot of pain.. While trying to fix that 3 mph difference on the differential cleaning grounds I done a ground check on the ABS system..I ended up taking that front bolt that holds it to the frame.. That’s how the ground returns, I was hooked up to the negative post on the battery and all I could get was infinity, so I took the bolt out and took some paint of to metal, and got a firm reading.. It’s paid off, because my evap control valve started working properly.. It doesn’t have anything to do with that system, but a bad ground can affect everything….
That ABS system has its own pump and can act like a spark gap transmitter like in the old days if not grounded properly..
Billme
Billme
Hattiesburg,Ms
Wow the key switch. More to consider. Does the ABS pump normally cycle on start up?
I would say so because it’s looking for , and using the differential speed signal..I would also think it has to prim as well, even for a second or two ..Of course I don’t know the full logic of it’s operation..That’s a grok question ready to be asked hehe
I do see the importance of cleaning those grounds after fooling with it..
Billme
Billme
Hattiesburg,Ms
The battery harnesses and key cylinder will be here tomorrow, so I asked grok which one should I install to see which was the main problem.. Grok said the harnesses since they feed everything, then the cylinder.. Sounds like a good plan..
Last night I wanted to drive and do another test, and yes got the PO 500, probably when I started it as usual, I wasn’t directly monitoring it, but this time, it didn’t seem to mess the motor up as usual and I hardly noticed..I asked grok why, and it said that ground cleaning on the ABS got the electrical noise down enough for the PCM to operate, so we are under the threshold now. Makes sense to me.
Billme
Billme
Hattiesburg,Ms
Btw, I have both harnesses for the battery and will put the ground on first then test, then the positive then test, then the cylinder if I’m up to it lol
Staff online
Lukin
