Point Me in the Right Direction, Please
Shotgun76
Suburban Chicago
I've got a '24 Expy Limited Max SPP w/ CCD.
The seatbelt warning while car running along with chime when exiting vehicle while running have reached intolerable levels of annoyance. I have tried the "seatbelt" method to disable and either it doesn't work or I'm missing a step. I saw some older FORscan posts where disabling was done in software. Anyone have any knowledge/directions on this one?
Also, how can I disable the "cross traffic" and ,"blind spot" alerts while towing? They seem to just randomly pop up on my dash while towing?
Lastly, I saw some older Forscan posts (reprogramming as-builts via spreadsheet) on adding actual temp redisplay to dash gauges but was wondering if there was a new direct method in Forscan?
TIA!!
DieselMonk
Atlantic Canada
There is a way to disable the safety belt warning manually, without a scanner. I did it a while back on my 24 Expy SPP and on a 25 Explorer. Works like a charm.
Google something like: disable safety belt warning Ford.
It like ignition on, step on brake pedal, buckle up then unbuckle for 3 or 4 times in a row and kinda forgot the rest.
You can do that for each seat.
Mr Big
Tampa Bay, Florida USA
TIA!!
The latest FORScan supports 2024 Expedition. You can find many items in the AS-Built section that support your model.
