1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Power running board is shot
Discussion in '3rd Gen - 2007 - 2017' started by Air00Max, Jun 26, 2013.
  1. Air00Max
    Air00Max Member
    Feb 26, 2013
    Cincinnati,OH
    My drivers side power running board on my '08 is dead. The motor went out. The dealer wants to charge $2300 to replace it. I can't find any aftermarket power boards. Has anyone had any successe with this ? $2300, especially for just 1 board, is ridiculous!! Would the power boards from ampro on an F150 be the same for an Expedition EL?? It is driving me nuts with this being broke
  2. bnvus
    bnvus Full Access Members
    118
    Jun 16, 2003
    Stafford, VA
    Try Car-part.com. I see they have several of them for around $100.
  3. Air00Max
    Air00Max Member
    Feb 26, 2013
    Cincinnati,OH
    I'm now getting really frustrated with this part. The cheapest board I cam find is $850. I am having a hard time believing the motor is bad because the board comes down just fine. It just won't go up. With just a tiny bit of a push from my foot underneath the board, then it will retract when I close the door. If it doesn't retract then I can actually hear the motor trying to pull the board up when I am driving. I have looked for any type Of obstruction to the board and can't see anything. I have tried greasing and lubricating the door switch/jam and that hasnt worked either. Does anyone have any other recommendations or websites I can look at to try and find the part cheaper ?
  4. RI-Matt
    RI-Matt Full Access Members
    445
    40
    Jan 13, 2011
    Rhode Island
    So is it the motor ??? Or is it the actual running board ??
    I think TascaFord sells the left side motor for only $295. Unless the bracket assembly is totally FUBAR I would look into just replacing the motor.
    Part #5
    2008 FORD EXPEDITION Parts - TascaParts.com
    Matt
  5. Air00Max
    Air00Max Member
    Feb 26, 2013
    Cincinnati,OH
    Matt thanks for the reply! I have not had any luck being able to find just the motor to try. Your link has really helped me out! For $295 I will try a new motor and see if that works.
    Mtrester92 likes this.
  6. dariod
    dariod Full Access Members
    90
    Oct 8, 2011
    Windy City
    I changed mines to manual ones. You can get regular running boards for cheap. I was able to sell my power boards for good money as I removed them when truck was brand new. Then i got oem EL regular boards and installed those.
    Haulin-Iron likes this.
  7. Air00Max
    Air00Max Member
    Feb 26, 2013
    Cincinnati,OH
    Back to square 1...Tascaparts.com has the wrong part/diagram listed for the part I need...A $295 part has now turned into a $1K part...still better than the dealership, but man this sucks.
  8. dariod
    90
    Oct 8, 2011
    Windy City
    Ohio winters and those power boards just dont like each other.
  9. CJ0920
    CJ0920 Full Access Members
    90
    Oct 10, 2012
    Gainesville, VA
    Your better off buying an aftermarket power folding steps.
    Sent from my iPad using Tapatalk HD
  10. Air00Max
    Air00Max Member
    Feb 26, 2013
    Cincinnati,OH
    That is the problem, there are no aftermarket power boards for an Expedition EL.
Share This Page
