1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Power Stop k5577-36 brakes
Discussion in '3rd Gen - 2007 - 2017' started by grdsman, Jul 10, 2020.
  1. 07navi
    07navi Full Access Members
    76
    1,592
    345
    Feb 3, 2020
    Mt.Shasta California
    Probably because they aren't ceramic.
  2. Snidley53
    Snidley53 Member
    66
    16
    Jun 13, 2019
    Indiana
    Grdsman, My rotors also had Front drivers side on both rotors but based on how the slots ran it ended up just being mismarked. I just put mine on today. I verified by checking online that they were good to go.
    grdsman likes this.
  3. 07navi
    76
    1,592
    345
    Feb 3, 2020
    And a 9 mm.
  4. grdsman
    grdsman Full Access Members
    46
    80
    28
    Sep 8, 2019
    Colorado Springs
    Yeah, I had hoped that they were mislabeled, but the slots ran the same direction on both rotors. They sent me the correct rotor and I’m good to go.
  5. UniqueTII
    UniqueTII Active Member
    35
    Dec 6, 2018
    Des Moines, IA
    I ended up "pressing" the bushings in with this setup and it worked great. The head of the bolt was on the plastic insert in the bushing.
    Trainmaster and Langer like this.
  6. UniqueTII
    35
    Dec 6, 2018
    Des Moines, IA
    I don't know what the heck is going on, but my brake pedal drops to the floor after swapping on these brakes. I've bled the system countless times, including while cycling the ABS pump with a Snap-On scanner and I just can't get good pedal pressure. Is there a chance that I killed a seal on a caliper or the MC when I pushed the caliper pistons back in? I'm not seeing any leaks or fluid drop.
Share This Page
