Powered Window Vent fuse location (for information) 2007 expedition EL
TammyExpedition
Indiana
2007 Expedition EL with powered rear window vents. Both stopped working. The Owner's manual shows Fuse 41 as 'NOT USED' --- This is incorrect. There's supposed to be a 15A fuse there that powers that circuit.
The switch assembly that goes to your sunroof, rear quarter windows and map lights comes out very easily after you open the sunglass holder. The wiring harness is the gray plug and you are looking for a ground on pin 7, and +/- 12V on pins 6 and 5 when the key is on.
Also found this great troubleshooting write-up that gives the rest of the circuit data:
JamaicaJoe
Oviedo FL
On my 2013 it seems those vents open only when the engine is turned off and ignition is in accessory. Perhaps due to carbon monoxide that would certainly enter if rolling along. I haven't fully tested to see if they automatically close.
