Pclaythomas
Well, just installed replacement cluster and.............nothing. Turns over but won't crank. Tried spare key, same result. The theft light is flashing fast,though. Wow, looks like I'm buying another vehicle.
This may or may not work. Did you try using a different key?
When you soldered and if it flowed onto another circuit you may have fried the board or shorted out the
PATS Antitheft System. The board works with PATS Antitheft System. If you replace the board or cluster you will need to go to a dealer to marry the board or cluster to the PCM. Before going to dealer try a good locksmith. Ask if they do the PATS Antitheft System Keys. If yes ask if they can do the system reflashing as well. Get quotes from dealer and locksmith. The dealers around here use locksmiths around here then upcharge you. Better yet the locksmith comes to you. While you're at it, if you only have one key it's cheaper to get a second while he's there.
Good Luck
TobyU the cluster is "married" to the PCM, if you disconnect it, you're not going anywhere.
DONT DROP IN THE TOWEL... Replacing the truck will cost you more than the repair depending on the extent you want to go with the truck.Well, just installed replacement cluster and.............nothing. Turns over but won't crank. Tried spare key, same result. The theft light is flashing fast, though. Wow, looks like I'm buying another vehicle.
