A couple of questions for FX4 drivers. First, and this would also apply to the heavy duty tow package vehicles, do you believe that you are getting significantly poorer gas milage because of the lower rear end associated with the limited slip set up? Second, do you believe that you have a slightly harsher ride than would otherwise be the case due to the shock absorbers in the FX4 package? (I wonder if that might be offset a bit by the taller profile tires on 18 inch wheel vehicles such as the FX4.) In general, would you order the FX4 package again if given the chance to do otherwise?
