Guys, should I use loctite on all the bolts I remove?
Don't say that lolBtw that Readylift thing is one weird design...makes the Daystar i had thought a flimsy POS look quite beefy in retrospect
Readylift is way better than daystar. Good luck with install. I put locktite on every bolt that is on Readylift spacer. Been on for almost 10k mikes now and zero issues
What a failure. I spent all ********* day on this and I failed. I was able to get the shock and coil out, but I couldn't get the shock and coil back on with the spacer on. There's two bolts at the bottom of the motorcraft shock that don't come off and I couldn't get the clearance to get the shock, coil, and spacer on. Then I ****** up a sway bar link and had to race to the auto parts store before they closed.
What's up with those two bolts on the shock? I'm so defeated right now.
I hammered them out which made it a perfect fit back in. Then impact drive them back through the splines and called it a dayWhat a failure. I spent all ********* day on this and I failed. I was able to get the shock and coil out, but I couldn't get the shock and coil back on with the spacer on. There's two bolts at the bottom of the motorcraft shock that don't come off and I couldn't get the clearance to get the shock, coil, and spacer on. Then I ****** up a sway bar link and had to race to the auto parts store before they closed.
I tried hammering them out, but didn't have any luck.I hammered them out which made it a perfect fit back in. Then impact drive them back through the splines and called it a day
