Haven’t seen anyone post this tip about installing the Rancho Quicklifts. When you’re trying to get the strut in, disconnect the tie rod, disconnect the sway bar link from the bottom of the control arm, to do that…jack up from under the control arm to put pressure the end link so it doesn’t spin the shaft, take the nut off, then slowly lower. It will give you A LOT more room by disconnecting the sway bar end link. Slide the strut in, install the three nuts on top loosely, you’ll then be able to get the bottom in with a little bit of finesse, tighten the three on top and torque the bottom and the rest. Reverse steps to put it back on. Got three of the four done today and ran out of light, will finish probably on Friday. Best of luck to any doing this. Thanks to all who’ve helped me make this decision on switching!
