Anybody use the Raptor Button config? I like the heated button on the wheel, and the Mode buttons. Coding most likely will be involved.
I tried but they didn't work properly. The pinouts are different. So the buttons did t actually do what the icons showed.
I did complete my install, super easy if I didn't have to do some of it 3 or 4 times. I love that it's prewired for the paddles but it kills me that for a $400 steering wheel, an $80k msrp vehicle doesn't just come with it. The raptor wheel is definitely nicer and more comfortable.
I had to disconnect the battery several times, once I figured out the buttons didn't work, and then a couple of times to straighten the wheel. It was off by just a few degrees so my advice is, before you take things apart, backup and pull forward several times in your driveway, to make sure the wheel is centered, then start the process. I didnt swap the button pods, I swapped the whole plastic piece with the pods still attached, as the raptor plastic had a speckled grey pattern instead of the stripes, just didn't match the rest of interior.
