Ready Lift 3-2 kit installed with CCD suspension
jen kirk
NC
No rubbing at all We have these tires (different sizes) on four Fords. My Expedition, F-350, F-150, and an Excursion. Best riding tires..
Lou Hamilton
Maryland
Did you use the new ReadyLift for the CCD models?
I see the kit comes with only to sensor mounts. Are there not 4 of them to re-adjust?
Also, did you install yourself or have someone install it for you?
Miekk
Madison Lake, MN
I see the kit comes it’s to sensor mounts. Are there not 4 of them to re-adjust?
Saw that also. There are 4 sensors, all 4 need something changed to make them think everything is normal.
Fozzy
Riverton
Big H had this kit installed and said Ready lift only need to move the front. He has pictures of the brackets installed.
Lou Hamilton
Maryland
i may have to call my local shop and see what they say. i think a normal ready lift for the f-150 was around $800 installed. they never did an Expedition before.
Miekk
Madison Lake, MN
The Shops in Texas, Cali, Utah etc..., that have been putting lifts on CCD vehicles tell me that all the sensors need to read as if nothing has been changed. Not moving them, or changing the rod lengths as in what I make for them, will send the wrong readings to the computer. The entire ride control module, the entire purpose of having CCD shocks, is based on the inputs from these sensors. The vehicle will not ride correctly as designed if the sensor arms are not at their original factory location.
jen kirk
NC
We had our local wheel and tire guy do the install.
we actually dropped off the vehicle and then he realized the ready lift would not work with the CCD. We googled and came across this thread and forwarded to him. Not sure exactly how it all went down but it turned out great
