JoeM
Are the rear brake caliper piston on a 23 Expedition screw in type or can I just compress them after putting the EPB in service mode?
Thanks
Thanks
I never worked on my brakes and always paid someone to do it for me. However, I believe 2023 Expedition calipers are screw in type and require a tool to rotate the piston.Are the rear brake caliper piston on a 23 Expedition screw in type or can I just compress them after putting the EPB in service mode?
Thanks
I've worked on several Ford rear calipers with E-brake including my '20 Expedition. All of them retract enough using the dash computer to remove the old pads; but, not enough to install new pads. To install new pads, linear pressure (no screwing) needs to be applied to completely retract the piston, C-clamp, brake piston tool, etc. Normally the piston has to be pressed in another 1/4" or so of travel after the piston is retracted electrically.Are the rear brake caliper piston on a 23 Expedition screw in type or can I just compress them after putting the EPB in service mode?
Thanks
Just to amend one thing, don't use a c-clamp, as you can possibly crack/crush the EPB mechanism compressing the piston. This is noted in the picture above from the service manual as well.I've worked on several Ford rear calipers with E-brake including my '20 Expedition. All of them retract enough using the dash computer to remove the old pads; but, not enough to install new pads. To install new pads, linear pressure (no screwing) needs to be applied to completely retract the piston, C-clamp, brake piston tool, etc. Normally the piston has to be pressed in another 1/4" or so of travel after the piston is retracted electrically.
Just be careful. I've used C clamps with no issue. The amount of force required is very small. I'm sure some have thumbs strong enough to press them back.Just to amend one thing, don't use a c-clamp, as you can possibly crack/crush the EPB mechanism compressing the piston. This is noted in the picture above from the service manual as well.
But the photo above says to gently rotate clockwise if piston isn't bottomed out? Kind of confusing....I've worked on several Ford rear calipers with E-brake including my '20 Expedition. All of them retract enough using the dash computer to remove the old pads; but, not enough to install new pads. To install new pads, linear pressure (no screwing) needs to be applied to completely retract the piston, C-clamp, brake piston tool, etc. Normally the piston has to be pressed in another 1/4" or so of travel after the piston is retracted electrically.
To be clear, my E-brake rear brake experience is confined to '19 and '20 Expedition and '21 and '22 F150 Rear brakes Other models and years may be different. The first one I worked on was my neighbor's '19 and we were very frustrated when the computer feature didn't fully retract the piston like the instructions indicated. So we were unsure how to proceed. I phoned a friend who said no problem, just press it back with your thumb, they all do that. The other 3 I've worked on were the same. I've discovered that I have less thumb strength than my friend. Note that the Expedition and F150 were unique designs that behaved the same.But the photo above says to gently rotate clockwise if piston isn't bottomed out? Kind of confusing....
They are screw type unless you do the electronic parking brake maintenance mode procedure. Once in maintenance mode you can just compress them. There are numerous youtube videos on activating and deactivating parking brake maintenance mode and how to replace the pads and/or rotors.Are the rear brake caliper piston on a 23 Expedition screw in type or can I just compress them after putting the EPB in service mode?
Thanks
