JSpa
What's up fellow Expedition owners? I've been troubleshooting an issue on my 2006 Ford Expedition. The left rear brake/turn signal is working intermittently. It does the standard annoying fast click when it's not working. The right works perfectly fine. Hazard signals work fine as well.
I'm no mechanic but pretty resourceful with google and a wrench. Here are the things that I've tried:
- changed bulb
- swapped right and left bulb mount. Right works fine with either setup, left still has an issue.
- checked fuses and can't seem to find a bad one, left turn signal works sometimes which makes me think it's not a fuse
- changed the turn signal assembly on the steering column
- greased the connections
None of this worked, so I took it to a mechanic. It wasn't a ford dealership but a local mechanic. He didn't charge me but also didn't seem like the type of mechanic that is intimately familiar with Expedition issues.
A few things I believe it could be:
- bad ground [not sure where to find this on my truck]
- BCM [mechanic suggested taking it to Ford to have them fix it]
- wiring issue
Ideally, I can resolve this on my own. Any suggestions? Has anyone had this problem?
Thanks in advance for your input.
- changed bulb
- wiring issue
