To address O.P.'s inquiry, which I came across during the same conundrum, only to find a solution shortly after, and for anyone here or searching online, what worked out PERFECT for this, was / is to take a carriage bolt with 1/2" threaded shaft x 1 1/2" long, hand thread/ push it inside new boot/sleeve about an inch, spray outside of boot with silicone lubricant (wont damage rubber) ...pinch flexible end inward first into caliper hole, push as much of remaining boot as you can by hand, then tap bolt head with hammer until entire boot is flush inside. The 1/2" diameter of bolt threads "grab" just enough of inner boot without expanding it, which guides it in while tapping and then final small amount is tapped/ control forced in by butting against inner part of head of carriage bolt. Then reverse-tap bolt out. SEE PIC.
