mistersmallz
I have 2019 ford expedition platinum with the max tow package. It’s rated to tow 9200lbs max/ 920lb tongue weight and has a payload capacity just over 1500lbs. I use it to tow a 34ft Keystone Bullet 290BHS travel trailer. It’s 6000lbs dry and 7000-7500lbs loaded with loaded tongue weight of about 850lbs. I’m using an Equilizer 4 point stabilizing WDH that’s rated for 14,000lbs max/ 1400lbs tongue weight. I originally had the same hitch rated for 10,000lb max/ 1,000lb tongue weight. The issue I was having was too much rear end sag with the expedition having independent rear suspension so I upgraded to a heavier duty hitch to resolve the issue. It did raise the rear end closer to the unloaded level but now I have a lot of “bounce” and “porpoising” while driving over bumps. Would sumo springs help with this?
