Shutterbug57
When I lock my truck with the key inside using the keypad, then open the truck with the keypad, the rear window is open. Is anybody else having this issue?
When using the keypad there is some combination of commands you can also input to open the hatch or the hatch window, it should be detailed in your manual.When I lock my truck with the key inside using the keypad, then open the truck with the keypad, the rear window is open. Is anybody else having this issue?
If you type just your code, the driver’s door unlocks. If you type code+3 all doors unlock. Code+5 opens the rear glass.
That depends on your settings I think. If I type my code all the doors open as that’s how I have my fob set (unlock button on fob unlocks all doors, not just driver’s).
Now if there was just a way to start the vehicle from the keypad or the door handle. If I can’t get to my phone or my watch or my keys and I’m loading up kids and stuff into a hot car, it’s be great to be able to start up from the door so it could get started cooling down.
