jdcrookshanks
Anyone know what this concerns? Saw this pop up this morning on the FordPass app. 2020 Expedition Platinum.
Recall 24E13 Powertrain Control Module Reprogramming
So instead of repairing the cause (bad transmission) the put out a bandaid repair for one of the symptoms..I believe this recall involves reprogramming the PCM to prevent the transmission from unexpectedly downshifting to first gear (from a much higher gear), while the vehicle is being driving at higher speeds (potentially causing the rear wheels to lock-up and throw the vehicle into a skid).
So instead of repairing the cause (bad transmission) the put out a bandaid repair for one of the symptoms..So instead of repairing the cause (bad transmission) the put out a bandaid repair for one of the symptoms..
Understood and thank you for the info.I have no control over Ford’s safety recalls - I was just trying to provide information.
Ford CEO Farley stated several years ago he was going to get a handle on the massive number of safety recalls and warranty repairs costs. I don’t think he has.
Not likely. Your link is to a TSB and it is for determining whether to replace the CDF clutch sleeve, and 24E13 is an actual Recall to reprogram a module.
I’m sure a lot of people would LOVE for this to turn into a recall. Me included.
Is this 100% to happen? Will they make an announcement or release a bulletin?Anyone know what this concerns? Saw this pop up this morning on the FordPass app. 2020 Expedition Platinum.
100% to happen.Is this 100% to happen? Will they make an announcement or release a bulletin?
Probably not...Saw Ford document, this software update is to prevent a false error code indicating low functioning catalytic converter. Local Ford dealer just came to home with mobile service to update PCM software.
Now a wonder if the $ $1500 I paid to replace my bank 1 catalytic converter about 2 years ago (at 88k miles) was really needed.
